  2. Error Reading L&G Meter
Error reading L&G Meter
By thiesens , 11 May, 2026
Gurux.DLMS.AMI
Hi Gurux
I have a wierd thing happening when I read an L&G Meter with the AMI.
I read the LP1 ProfileGeneric, and I see this in the agent-logs:
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: info: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 2
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 8
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 5
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 6
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 3
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 7
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 4
It seems it is ignoring everything.
1 month ago
Hi, Did you add them…
Did you add them manually or use the existing template?
This is checked and I'll let you know later today.
thiesens
1 month ago
I created a template device…
I created a template device in GXDLMSDirector, imported as template in AMI and created the device based on the template
1 month ago
Hi, Is your meter using…
Is your meter using Short name or logican name referencing?
Let me know this, and this is tested.
thiesens
1 month ago
Meter is L&G, and is using…
Meter is L&G, and is using Short Name
1 month ago
Hi, Short name referencing…
Short name referencing is tested after lunch. I'll keep you posted.
4 weeks 1 day ago
Hi, This is fixed, and the…
This is fixed, and the new version will be released tomorrow.
